zend - enviar variable a layout
class Zend_View_helper_prueba { static public function prueba() { $var = 'variable'; return $var; } }
<?php class Mi_Layout_Plugin extends Zend_Controller_Plugin_Abstract { public function preDispatch(Zend_Controller_Request_Abstract $request) { $layout = Zend_Layout::getMvcInstance(); $view = $layout->getView(); $view->whatever = 'valor'; } }
Luego debes registrar ese plugin en el controlador de la siguiente forma:
Zend_Controller_Front::getInstance()->registerPlugin(new Mi_Layout_Plugin());
