Problema sincronizando paquete de BeautifulSoup
raceback (most recent call last): File "C:\Documents and Settings\EC.32\workspace\ec\ec\manage.py", line 11, in <module> execute_manager(settings) File "C:\Python26\lib\site-packages\django\core\management\__init__.py", line 438, in execute_manager utility.execute() File "C:\Python26\lib\site-packages\django\core\management\__init__.py", line 379, in execute self.fetch_command(subcommand).run_from_argv(self.argv) File "C:\Python26\lib\site-packages\django\core\management\base.py", line 191, in run_from_argv self.execute(*args, **options.__dict__) File "C:\Python26\lib\site-packages\django\core\management\base.py", line 219, in execute self.validate() File "C:\Python26\lib\site-packages\django\core\management\base.py", line 249, in validate num_errors = get_validation_errors(s, app) File "C:\Python26\lib\site-packages\django\core\management\validation.py", line 36, in get_validation_errors for (app_name, error) in get_app_errors().items(): File "C:\Python26\lib\site-packages\django\db\models\loading.py", line 146, in get_app_errors self._populate() File "C:\Python26\lib\site-packages\django\db\models\loading.py", line 61, in _populate self.load_app(app_name, True) File "C:\Python26\lib\site-packages\django\db\models\loading.py", line 83, in load_app if not module_has_submodule(app_module, 'models'): File "C:\Python26\lib\site-packages\django\utils\module_loading.py", line 17, in module_has_submodule for entry in package.__path__: # No __path__, then not a package. AttributeError: 'module' object has no attribute '
Saben que puede estar pasando y que puedo hacer para solucionar el problema? Gracias de antemano.
